Injector Cut in desaceleration
Dariusz
Post by Dariusz »
I'm using 750cc injectors and I like to know how to make that if I desacelerated the car (throttle in 0% open) to make that the injectors close.
Thanks in advance, I need this because I have very good A/F in 100% throtle but my fuel use in normal driving is very hight.
Dariusz
Dariusz
Post by Dariusz »
Hondata wrote:Decel fuel cut off is built in. The injector is cut based on TPS and RPM, switching back on about 400 rpm above idle speed. If you are not getting decel injector cut then check your TPS adjustment - chances are the TPS is set slightly high.
What is the process to check the TPS adjustment? Is a option in the Rom Editor or is a mechanical work?
Thanks a lot for the ansver.
Dariusz
