Turbine mass flow?
touge tom
Turbine mass flow?
Post by touge tom »
As topic heading suggests, turbine mass flow? The factory unit has 79 g per second as it's settings. If I was to use a mhi2 and all the info on the Internet says it flows 33% more. Would I just put 105 g per second in that section of the program?
Re: Turbine mass flow?
Yes. I don't think the exact number matters as much but if too low the ECUs logic tells it that if the turbine cannot flow more than 79 g/s, then it may as well open the wategate when the modeled flow reaches that value.
touge tom
Post by touge tom »
Thanks heaps👌
