Vacuum gauge and CAN gauges
lurice0
Post by lurice0 »
I see s300 has a MAP sensor in the options available for display which shows "/psi but that doesn't actually count as an accurate vac/boost gauge. does it? Probably not
So if i need to hook up a vac/boost gauge can i get a CAN gauge or some kind of gauge that hooks up to s300 v3 so that the vac/boost numbers show up in display of Smanager or even the mobile app, for datalogging? And so that i can avoid having a gauge pod?
Re: Vacuum gauge and CAN gauges
That is very accurate as it is reading from the MAP sensor that the vehicle uses to run from.
