TCP Streaming
Haltamer
TCP Streaming
Post by Haltamer »
I was wondering if there was any more technical documentation available on the TCP Streaming functionality for the mobile app?
I've found the Bluetooth technical documents which I suspect cover the packet structure, but a bit of an overview of what setup would be needed to ingest the data, or at least the format the stream is arriving in would be very helpful :)
Haltamer
Re: TCP Streaming
Post by Haltamer »
Ooops...
First tests haven't gone very well :)
I've had a go at running a TCP stream to Packet Sender (Also a receiver ;) ) on my device, but every time recording is started via the mobile app, there's an immediate crash to home screen.
I've attached the crash dumps that are available - I am using a 16 Pro on iOS 26 Dev Beta 8 (Which may not help proceedings)
No packets received prior to the crash - It's instant upon pressing the record button under plots.
Haltamer
Re: TCP Streaming
Post by Haltamer »
And attaching the TCP Settings...
As a note, I have tried with Single / Multi file and various sample rate settings.
The crash occurs with any IP set, and seems to occur regardless of if the Flashpro is connected or not.
Re: TCP Streaming
You should contact the software developer though the app store for this.
