Error code 9,13,16
Posted: Fri Sep 05, 2025 12:30 pm
by lester1968
Hello. I have a P29 ECM that according to Hondata is compatible with the S300. Well, I installed it and the engine (D16A9) turns on, but it doesn't go above 3500 rpm, and I get errors 9, 13, and 16, in addition to an oxygen sensor error, which it doesn't even have. Were you able to resolve your problem?
My car is a Del Sol 1992 D16A9 engine and P29 ecu.
Re: Error code 9,13,16
Posted: Fri Sep 05, 2025 1:02 pm
The first error has to do with the distributor and must be resolved.
The other errors can be disabled in the misc. section of the parameters window.
Posted: Fri Nov 21, 2025 9:39 am
by lester1968
Thanks for the reply. I checked the distributor and everything seems fine; the readings are within acceptable limits.
However, DTC 09 remains. The car runs fine with that error, but now it won't go above 2500 RPM (approximately), and I see that the TPS reading isn't increasing.
I replaced it, and it seems fine, but after a while, the same problem occurs. In fact, I noticed that with the car off, if I connect my laptop, the TPS works fine, but when I start the engine, it goes haywire again.
Has anyone else had this problem?
What could it be? Could the error 9 be related to it?
Posted: Fri Nov 21, 2025 11:41 am
You should try your ECU on a known working vehicle and see if the same errors occur.
