2023 Si 240 CARB Tune
Civic 2016+ 1.5 Turbo
DanielBL
Post by DanielBL »
I have a 2023 Si with the 240 CARB tune uploaded. So far so good and no issues at all. However, I disabled Hondata mode before uploading.
To clarify, does this mean I'm on stock power all the time? Will I only get full "240 CARB" power if I re-upload with Hondata mode enabled? Or is the engine still making more torque than stock even with Hondata mode disabled? I certainly feel like there is an extra kick even with Hondata mode disabled.
Thank you!
Re: 2023 Si 240 CARB Tune
Disabling that means that you have the same power levels in both modes
DanielBL
Post by DanielBL »
Yep, thanks! That part I understand, but when it's disabled, is the power level at a stock level or still slightly more than stock?
And if Hondata Mode is enabled, going into Sport Mode is when I assume the the full "240 CARB" power is available?
When it is disabled, there is no switch to go between power levels. They all have the same power as the reflash you have uploaded.
