DE5 Fl5 Reason pops and bangs are not working and feature request
jpierro79
Post by jpierro79 »
I noticed during tuning that my customer's DE5 pops and bangs didn't work even on the factory Integra settings. The reason is the chart is tracking idle area only and when I put negative timing in the idle area of the pops and bangs, they began to work again.
Also please there has to be a way to track the wastegate position in the wastegate position chart or some sort of access to PID boost control. This way I can tune in better accuracy for lower rpm boost on larger turbos for both Integra Type s and FL5.
Re: DE5 Fl5 Reason pops and bangs are not working and feature request
This table?
Is your air change under 15 g/s on overrun? Seems likely. In that case I'll make the changes to the factory tables.
