4k rev limter gear 2 3 4 5
365motorsports
Post by 365motorsports »
I have a 4k rev limit for some reason all gear above 1st. checked all my settings i cant seem to find whats wrong.
Re: 4k rev limter gear 2 3 4 5
I do not see it hitting any rev limits in the datalogs.
365motorsports
here are some more specific to the issue.
365motorsports
Aem Wideband gauge goes fully lean. 1st it won’t rev passed 4500. 2nd 3rd won’t go passed 4000
What happens if you set a rev limit of 2000 RPM?
365motorsports
There is no rev limiter set that low. All the rev limits I set at 8k this morning. Set boost cut coolant temp to 200 degrees. Launch control is turned off. Not sure what else to do
365motorsports
I figured out my map sensor issue with the s300. Pro 1 cams went out of time from where I degreed them. Starts runs great can’t tune it bc of the mysterious 4k rev limiter.
365motorsports
365motorsports
You talking about the main rpm rev limiter?
yes
365motorsports
I’ll try that on my way home
365motorsports
Rev limiter works at 2000 rpm but when input it back to 8k 10k etc it still rev limits at 4000 rpms
365motorsports
Wow man. S300v3 is brand new but I have to pay for the rma and shipping. Board is bad causing this issue.
The s300 was sold in 2021 and is out of warranty
