Hondata 4bar not letting car start in s300
SicilianBoost
Post by SicilianBoost »
brand new chip from hondata, brand new ecu, car starts and idles abit low, everything has been adjusted, brand new build, but the issue i am having is that when i select the replacement map sensor to hondata/omni 4bar, car will not start, return to stock option (4bar still installed) and the car starts, but the the car wont drive under throttle, as i said the tps is proper in its function
Re: Hondata 4bar not letting car start in s300
Post the calibration used as well as a datalog showing the issue.
SicilianBoost
I do appreciate your response, however, the issue now I have is that Hondata does not have an ignition signal..
I have been over every test with a meter and such for the systems related to possible electrical issues, and it all seems to show as proper. SO could i just have a basemap that far off?
94 Honda Civic Coupe
96 B18b1 ( P06/s300)
OBD 1
There is a distributor error according to the sensor list in the datalog. Is this an aftermarket distributor?
