Kpro 4 digital dash can bus not reading
Plumberguy76
Post by Plumberguy76 »
Installing a powertune digital dash in a 2002 rsx.
Resistors inplace 60 ohm reading. Showing voltage on output of can bus..wiring checked..canbus turned on in kpro showing nothing... sure I'm missing something in kpro
Re: Kpro 4 digital dash can bus not reading
Are you using a 60ohm resistor instead of a 120ohm resister?
Plumberguy76
A 120 at the ecm and I think the display has a 120 so im reading 60 at the can extender at the plug. Which is mid ways between the 2
Only one resistor should be used.
