FK8 calibration upgrade message
Dani7792
Post by Dani7792 »
Hi, My calibration was performed in April 2025. Now, when I connect Hondata to the car, this message appears, but I don't know how this affects the map or if I need to reload the map after updating it. Will it change any data in the map I already created? Does it require an internet connection to update? What should I do?
Thanks.
jeffx
Re: FK8 calibration upgrade message
Post by jeffx »
if everything is working as intended you should be okay to ignore the message.
The reason you're seeing that message is since you've uploaded the calibration 6 months ago, Hondata has updated the Flashpro firmware as well as Flashpro Manager a number of times so there are more tables and parameters available to tune. There may be more datalogging channels that were added as well, so you wouldn't be able to view those in your logfiles unless you uploaded your calibration again with the latest version of FlashPro Manager.
It is recommended that you reupload your calibration to the ECU using the new software so that everything is up to date. There may also be bug fixes in the newest software.
Dani7792
Post by Dani7792 »
thank you guys, let's try to upgrade map.
Regards.
