Hondata idle speed setting does not take effect.
Civic 2016+ 1.5 Turbo
wkk
Post by wkk »
Hello Hondata,
I own a 2019 Honda 10th-generation Civic with a CVT transmission. The applicable FlashPro version is 4.6.0.0, and the serial number is FP-16CIVIC-L15T-INT-220557. When I set the idle speed to a different value, such as 740 RPM, this setting does not take effect in Drive (D) mode. In Neutral (N), the idle speed changes to my set value of 740 RPM. However, when I switch to Drive (D) and press the brake, or when using the auto-hold function, the idle speed remains at the default Honda setting of 630 RPM.
As you may know, when the idle speed is at 630 RPM, the vehicle noticeably vibrates.
I have tried multiple times to change the idle speed to other values or reupload the tune, but I have not been able to resolve this issue. I have attached screenshots of my program and logs below. Could you provide me with some suggestions or solutions?Image[/img]
