Unable to change volts to psi
deafy03
Post by deafy03 »
What am I doing wrong here? Trying to get the analog input AN0 to log in psi but it only has the option of voltage>
Re: Unable to change volts to psi
You should not need to use the sensor setup window for this to work.
