sensor spikes when datalogging
sam@hickshaven.com
Post by sam@hickshaven.com »
The s300 gets sensor spikes when datalogging, I’ve checked all the ground and tried a new ecu still does the same
Re: sensor spikes when datalogging
Are you using resistor or non-resistor type spark plugs?
sam@hickshaven.com
Resister type
Post the calibration and datalog showing the issue
sam@hickshaven.com
ERROR.s3d
And Im using the stock p75 base map
sam@hickshaven.com
sam@hickshaven.com wrote: Wed Nov 19, 2025 9:54 pm ERROR.s3d And Im using the stock p74 base map
Who socketed the ECU?
sam@hickshaven.com
I did All the soldier joints look fine
Have you tried this s300 on a known working ECU?
You should try the s300 on a known working ECU to see if it is the ECU or the s300.
sam@hickshaven.com
It’s the s300
sam@hickshaven.com
Is there anything you can guys can do about it?
sam@hickshaven.com
It’s 58820
Post pictures of the soldering on the bottom of the ECU showing the areas that were soldered for the s300 socketing.
