Page 1 of 2
sensor spikes when datalogging
Posted: Tue Nov 18, 2025 11:05 pm
by sam@hickshaven.com
The s300 gets sensor spikes when datalogging, I’ve checked all the ground and tried a new ecu still does the same
Re: sensor spikes when datalogging
Posted: Wed Nov 19, 2025 10:05 am
Are you using resistor or non-resistor type spark plugs?
Posted: Wed Nov 19, 2025 10:25 am
Resister type
Posted: Wed Nov 19, 2025 12:30 pm
Post the calibration and datalog showing the issue
Posted: Wed Nov 19, 2025 9:54 pm
ERROR.s3d
And Im using the stock p75 base map
Posted: Thu Nov 20, 2025 3:58 pm
sam@hickshaven.com wrote: Wed Nov 19, 2025 9:54 pm ERROR.s3d And Im using the stock p74 base map
Posted: Thu Nov 20, 2025 4:01 pm
Who socketed the ECU?
Posted: Thu Nov 20, 2025 4:19 pm
I did All the soldier joints look fine
Posted: Thu Nov 20, 2025 4:48 pm
Have you tried this s300 on a known working ECU?
Posted: Fri Nov 21, 2025 11:51 am
You should try the s300 on a known working ECU to see if it is the ECU or the s300.
Posted: Sat Nov 22, 2025 9:05 pm
It’s the s300
Posted: Sat Nov 22, 2025 9:30 pm
Is there anything you can guys can do about it?
Posted: Mon Dec 01, 2025 2:39 pm
Posted: Wed Dec 03, 2025 9:50 am
It’s 58820
Posted: Wed Dec 03, 2025 12:16 pm
Post pictures of the soldering on the bottom of the ECU showing the areas that were soldered for the s300 socketing.
