Won't start after FlashPro update.
GhostieTR
Post by GhostieTR »
I have a 2017 FK8 and it now won't start after update.
I updated my program and then my Flashpro. I wanted to put my fk8 back to factory but now its stuck in Recovery mode. I read that I have to unplug EVERYTHING and then plug it back up to try again.
I also deleted my old tune from the Pro as well.
After reinstalling my old tune and retrying back to stock, it still won't turn over. It'll show "Recovery Mod" and then switch to green but it still won't start.
Any help on want to do would be appreciative.
GhostieTR
Re: Won't start after FlashPro update.
Post by GhostieTR »
Now it says ! Jailbreak: Yes
Rares
Post by Rares »
Most likely your battery is discharged (less than 11.5-11.6v) and the reflash cannot be completed. Connect a charger to the battery, but it is very important not to disconnect the battery even for a moment.
After charging the battery a little, you can try to reflash again.
GhostieTR
Post by GhostieTR »
I tried that a few times now and still the same issue. Battery is currently 12.54.
I'm currently trying to just put it back to Stock and it still won't start. When I push the START button after the time is completed, I'll push it, it beeps at me, Ill push it 2 more times and then the ignition finally turns off.
What is the serial number of the FlashPro?
GhostieTR
Post by GhostieTR »
FP-CTR-US-354444
GhostieTR
Post by GhostieTR »
Hondata wrote: Mon Dec 08, 2025 8:33 am What is the serial number of the FlashPro?
FP-CTR-US-354444
GhostieTR
Post by GhostieTR »
Spunkster wrote: Mon Dec 08, 2025 10:08 am With everything plugged in and the ignition in the on position, go to the Help menu and click on “send feedback”. Include a detailed description of the issue.
I did last night.
GhostieTR
Post by GhostieTR »
Update. The FlashPro cuase an internal voltage code that wouldn't allow the car to start. Had to get a reader to clear it.
jeffx
Post by jeffx »
For the sake of completeness (and for anyone searching due to a similar issue in the future), can you share what was the DTC and what type of tool was required to clear it?
