FlashPro Baseman MAF vs MAP Options
k20z_vtech_8k
Post by k20z_vtech_8k »
Hi,
I just bought a Hondata flashpro for a 8th civic Si, with just a K&N v2 SRI, and I'm new to Hondata and Flashpro. I watched some YouTube videos where flashpro basemap in "new calibration" in Flashpro Manager that would give you 2 sets of calibrations, one set for MAF and another set for MAP. In the latest Flashpro manager, the basemap calibrations don't show MAF or MAP in the title though.
There is a K&N v2 SRI basemap in Flashpro Manager for the 2006 Honda Civic Si. Does that one K&N v2 SRI basemap support both MAF and MAP at the same time? How does that work? If I select "MAF" in Fuel, then it loads the K&N v2 SRI MAF calibration to my car? If I select "MAP" in Fuel, it loads the K&N v2 SRI MAP calibration to my car?
Thanks!
k20z_vtech_8k
Re: FlashPro Baseman MAF vs MAP Options
Correcting typo. It's Basemap, not Baseman...
The calibrations can be switched between MAF And MAP in the fuel section and it defaults to these calibrations.
k20z_vtech_8k
Thank you very much!
k20z_vtech_8k
Sorry. Just to make sure I understand it correctly.
If I want to use MAP, uncheck the MAF box and check the MAP box?
If I want to use MAF, check only the MAF box and uncheck the MAP box?
There reason I ask is that the MAF and MAP options can be checked simultaneously.
Thanks,
Brian
Please see the details in the help file at: https://hondata.com/help/flashpro/fuel_ ... %2Bdensity
