Kpro for s2000
johnwick tuning
Kpro for s2000
Post by johnwick tuning »
Hello fellow Honda enthusiast
I am here to see if anyone can help me with a s2000 Kpro
The car came with it and the motor went and I swapped a k24 in it
And i re-pin a k swap harness for the s2000 cool everything is working but what I need help with is adding vtc cam sensor and vtc
actuator I check all pins but I’m assuming in the base rom moves pin around can anyone help me find the pin out or tell me what pinto use
Thank you guys so much
Re: Kpro for s2000
What is the serial number on the K-Pro board inside the ECU?
johnwick tuning
Re: Kpro for s2000
05004707
Re: Kpro for s2000
That ECU is not designed to work with VTC as it only will work with the S2000 engine.
johnwick tuning
Re: Kpro for s2000
Shooott that’s kinda sucks if I get another board would I be able to do what I’m trying to do ? I’ve already re pinned everything
Re: Kpro for s2000
I would recommend selling the ECU/K-Pro you have to someone with an s2000 and then getting a K-Pro and ECU that is meant for an RSX or engine swap and use that instead and you will have to do all the custom wiring.
johnwick tuning
Re: Kpro for s2000
lol thanks I already had done it but thank you for answering
