Hi,
Flashed a Hondata K&N v2 SRI basemap with MAP selected and MAF disabled, and noticed knocking count. Would really appreciate to get some help here, to reduce or fix the knocking so the car would be drivable.
I have a 06 Civic Si with K&N SRI. Flashed the Hondata K&N v2 SRI basemap calibration. Monitored engine knocking after that. < 3k rpm city and highway driving no knocking. At 3.2k to 3.3k rpm, 3 knocking count at cylinder 2 and 28 knocking at 28 count at cylinder 4. Had no idea what to do now.
Should I go to the Fuel Low Table and try to add fuel per MAP pressure and pre RPM? Is there a specific pull condition I need to do in order to get meaningful datalog for tuning fuel?
I disabled the P0101 code in OBD2 diagnostic by the way.
Thanks!
Help: 06 Civic Si - K&N SRI Basemap Knocking
k20z_vtech_8k
Re: Help: 06 Civic Si - K&N SRI Basemap Knocking
You should reduce timing in the areas you are getting knock.
k20z_vtech_8k
Thanks! Is there a Hondata instructions or links that show how to go about doing that?
- CalibratEd
- Contact:
I can help with some minor adjustments. Post the calibration file you are running.
-Ed
-Ed
Instagram: calibrated.tuning
