hondata ecu problems
tokuisport
Post by tokuisport »
here is my problem. i finally got to hook up my hondata presocketed ecu with the s200 on to my car (2000 integra gsr) a couple weeks ago. the car started up and ran just fine for me no problems. but for some reason this week the car wont even stay running. it would just crank start up to about 1000-2000rpms then drop and die. i was wondering what was wrong checking everything and everything looked and checked out fine. so i tried remvoing the eprom from the hondata ecu and the car started but ran really shitty. so i was like i hope its not that eprom that is giving me this issue of not running when it ran fine before and now is acting up. so then i went and got my factory p72 obdII ecu and hooked that right up and the car started and ran like there was no problems at all besides having a check engine light for some of the obdII sensors n stuff i dont have hooked up.
doesn anyone know if i getting a new base map eprom would solve my problem? because i dont know what i should do besides that.
any suggestions will be very helpful :!:
Who provided you with the basemap? You should get the car to a tuner as soon as possible and get it tuned peroperly.
tokuisport
past 2 weekends i started and ran the car with the hondata presocketed P28 with the ship in just fine. this last weekend the car wouldnt run at all with the hondata ecu with the chip.
if i remove the chip from the hondata ecu the car ran but really badly.
then if i put the factory p72 (obdII) back in and the car started up like it had no problems
can you please answer the question?
tokuisport
i dont know who provided becaause i bought all of this from some kid in cali
You should contact one of our dealers/tuners for a proper base map and see if that resolves the problems.
