Did the swap, I got to drive 30 miles to get it tuned. Dont want to hurt the motor. So 2007 tsx k24a motor, rbc intake, pl
Tb spacer, 70mm tb, 50 degree cam gear, rdx 410 injectors, plm 421 header, k&n typhoon CAI, AEM wideband x uego obd2.
Running stock basemap, the setting i changed are... current injector size 410, under closed loop inout secondary o2 sensor enabled, under lambda -wideband ect2, switched to speed/density map. Thats it new here, think this will get me there alright taking it super easy and nothing past say 3000 rpm?..
Basemap adjustments k24a swap
- CalibratEd
- Contact:
Re: Basemap adjustments k24a swap
Post the file and a log. I can take a look at it and let you know how it’s running.
-Ed
-Ed
Instagram: calibrated.tuning
