Hondata FlashPro
Civic 2016+ 1.5 Turbo
Staneytham
Hondata FlashPro
Post by Staneytham »
Halo , I’d like to confirm something about Hondata FlashPro.
I’m currently driving a Honda Civic FC 1.5T (L15B7) and plan to use Hondata FlashPro on this car first.
In the future, I plan to upgrade to a Civic FL5 Type R. My question is:
• Can I reuse the same FlashPro on the FL5 after I uninstall it from the FC?
• I understand that the FC ECU does not require a jailbreak, but the FL5 ECU will require a separate ECU jailbreak.
• As long as I reflash the FC back to stock and uninstall FlashPro properly, the device should be free to bind to the FL5 ECU — is this correct?
I just want to make sure I’m following the correct process and not locking the FlashPro to one vehicle permanently.
Thanks in advance.
Re: Hondata FlashPro
I'm sorry, but that FlashPro is not compatible with the Type R. You will have to sell that FlashPro and purchase the correct one.
