Motec MAP sensor
wpayson
Motec MAP sensor
Post by wpayson »
I am looking to buy a Motec 3 bar MAP sensor to use with the available calibration on the K-Pro. Does anyone know the part number of the sensor that I would need to use with this calibration? I am having a good bit of trouble finding exacly the one I need and with the right voltage.
Any help is much appreciated!
They are available through any Hondata dealer for $90.
wpayson
Post by wpayson »
Spunkster wrote:They are available through any Hondata dealer for $90.
That sounds like the GM sensor. I was under the impression that the Hondata guys were unsure of the difference between the older model MAPs and the newer MAPs. The Motec MAPs run on a slightly different voltage than GM ones do. But I can get them from Hondata dealers? Any info on part numbers?
Just ask for the Motec 3-bar from Hondata when you call the dealer....they can order it.
wpayson
Post by wpayson »
Spunkster wrote:Just ask for the Motec 3-bar from Hondata when you call the dealer....they can order it.
Thanks, Spunkster. I appreciate your help. :D
