hondata no vtec p28
turbocivic4
hondata no vtec p28
Post by turbocivic4 »
Well I have my hondata here for months and I never tested it , so I burned a p72 program on the p28 ecu and ran my gsr. There isnt any vtec engagement, what gives????
Are all the parameters being met to engage vtec?
turbocivic4
Yeah , cause right after i switched to my stock ecu and it worked fine, im a try to reburn the chip today and see what happens
But have all the parameters been met that you have specified on the HOndata rom image...minimum map pressure, rpm, etc?
turbocivic4
Is the Fix Vtec Revs in ECU supposed to be clicked, cause on the basemap its not clicked
Vtec revs 4807 and its unchecked, guess its supposed to be checked why isnt it checked for a basemap?
If it is not set in the ecu that would explain why your vtec is not engaging. You should contact your dealer and have them create a new basemap, or if you have the software you can make the change yourself.
turbocivic4
ok, and if I do my lambada conversion for my uego on the stock map, when im not using my uego will the stock sensor be reading the correct signals?
