JDM K20A engine harness to kPro V4 PND ECU
Hbgdaddy
Post by Hbgdaddy »
I am in Thailand doing a kswap. I bought a 2004 JDM K20A. It came with ECU PND 013. I am using the Hondata KPro V4 PND A07 ECU. I am also using the Hybrid racing universal conversion harness as the 1994 EG hatch did not come with fuel injection. I found the JDM engine harnessPrimary Oxygen sensor wires were missing in 2 spots on the engine harness A plug and C101 connector, A16 to C101 13 and A22 to C101 15 are missing. The other O2 sensor wires are there, A1 to C101 10 and A6 to C101 19.
Can I add the 2 missing wires and call it good?
Do I need to fix any other engine harness differences? Thanks
Re: JDM K20A engine harness to kPro V4 PND ECU
I would discuss this with whoever made the harness you are using.
Hbgdaddy
Post by Hbgdaddy »
I am using the harness that came with the engine. It is a JDM (maybe a Euro) harness. And I am using the hybrid racing universal conversion harness. I hope someone else has had the same issue. Thanks
Hbgdaddy
Post by Hbgdaddy »
Maybe if I had the pin out for the JDM 37820 PND 013 ECU, I could compare it to the Hondata KPro V4 to see the differences? I have seen posts that say they are different but no pin out. The Oxygen sensor wiring must be different because the stock engine harness did not have the two O2 sensor wires from the c101 plug to the ECU A plug. Thanks again
