Integra
Quad_4life
Integra
I’m taking the s300 with no atm from a civic and putting it in my obd1 integra. What modifications do i have to make. Thanks!
Re: Integra
What do you mean by no atm?
Quad_4life
Re: Integra
Not sure, i asked what it is and he said its a s300, not atm
Re: Integra
I do not know what you mean by that.
Quad_4life
Re: Integra
Not sure, but just for any s300, what are some things i have to do or what do i have to be careful of when taking it from a civic to a obd1 integra?
Re: Integra
Please give the serial number of your s300, the exact model and year of your vehicles, and explain fully what you are doing.
Quad_4life
Re: Integra
Not sure where i find the serial number. It’s a 2000 acura integra. Obd1. P75. I used to have a p28 with a sst chip but swapping it out for this. The guy told me i have to cut a data wire or something. I just want confirmation on what wire and if there’s anything else to doHondata wrote: Sun Jan 11, 2026 9:38 am Please give the serial number of your s300, the exact model and year of your vehicles, and explain fully what you are doing.
Re: Integra
Are you trying to use it outside of the case like that?
What is the issue you are having with it?
Quad_4life
Re: Integra
No that’s just how i bought it, i will put it in a case. I’m not having any issues, i just want to know what modifications to do before putting it in. I’ve been told there’s a data wire i need to cut or something.
Re: Integra
Please make sure it is properly installed in the case, then use it and see if it is working correctly.
Quad_4life
Re: Integra
The guy i bought it from told me i had to cut a data wire or else it will feed back into the ecu and lock it upSpunkster wrote: Mon Feb 02, 2026 10:14 am Please make sure it is properly installed in the case, then use it and see if it is working correctly.
Re: Integra
We cannot troubleshoot a hypothetical issue. You need to try using it and if there are issues, we can go from there.
Quad_4life
Re: Integra
i don’t want it to get bricked. Is there any different procedure to do when taking it from a civic, and putting it in a integra.Spunkster wrote: Tue Feb 03, 2026 10:02 am We cannot troubleshoot a hypothetical issue. You need to try using it and if there are issues, we can go from there.
Quad_4life
Re: Integra
My car has no motor right now and have no intent on making it run soon. But from what ive been told is i have to cut a data wire before putting it in the car or else it will get bricked. The guy a bought it from said it happenned to a guy he knows when he sold him another ecu. it is possible that it was bricked when he sold it but i doubt. So im wondering what to do before putting the p75 with a s300 into my car that used to have a p28 with a sst chip.The p75 is coming from a civic and going in my integra, he said that thats where theres an issue, that the integras have an extra wire compared to the civic.
Re: Integra
Nothing else should need to be done except put int in the vehicle, turn the ignition on and then upload and use it.
