"erase ECU (clear security)"and now it does not connect us to kmanager "Off Line"
manute
Post by manute »
Hello, I have problems with my HONDATA KPRO3 (13482). In kmanager we click on "erase ECU (clear security)", since it was blocked with a code and now it does not connect us to kmanager "Off Line".The ecu was erased with version KManager 4.6.1. I would be very grateful if you could give me a solution.
Thank you.
Re: "erase ECU (clear security)"and now it does not connect us to kmanager "Off Line"
What do you mean that it was blocked with a code?
manute
Post by manute »
The previous tuner password-protected it to prevent copying the map. I clicked on "erase ECU" and now it won't let me do anything.
Is the ECU in the vehicle with ignition in the on position?
manute
Post by manute »
Yes, it says "driver installed" and "off line"
Send an email to support <at> hondata.com with the following and I will issue an RMA and give you further
instructions:
Name:
Address:
Phone:
Email:
Serial#:
Description of problem:
include a link to this thread.
