Flashpro 4.6.3.0 "Boost by gear" table BUG
chameleontuning
Post by chameleontuning »
Ive had this issue with a few previous versions and now with the new one checked to see if somehow it got fixed but nope, still there.
with flashpro open, im loading up a 2025 FL5 calibration ( not sure if any other calibration affects this ) and in the Boost by gear table, i will select 3rd gear and highlight a few cells, click "Control + J" for quick adjustment and enter a number and hit enter. nothing happens to the gear i am in. all changes default to ONLY gear 1. the only way i can make edits is manually enter numbers in each cell, or copy and paste from another cell.
Re: Flashpro 4.6.3.0 "Boost by gear" table BUG
I just tested this and cannot reproduce what you are describing.
Post the calibration here.
chameleontuning
my mistake on my wording. the issue has to do with the "Map Select" 1-5
you can select Map 3 and make changes with Control J and it only applies the changes to Map 1.
Map select, tune select.. the table itself is RPM VS Gear.
Btw i just created a new file and it still does it.
Does it appear to change the value for the correct gear or does the change show against 1st gear?
Can you give a step by step to reproduce?
chameleontuning
Ok so i realize the problem is me, BUT something still feels off..
to reproduce this the "ALL" button has to be enabled, you can view all the maps, and if you decide to make an edit it only applies it to Map1.
the logic im seeing is if i want to edit that selected map i should be able to at any time BUT "ALL" option will just use Map1.
Basically i can still manually edit each cell by hand, BUT using Control + J only works when a certain map is selected.
No, it is a bug. 'All' does not update all the tune tables. Fixed for the next release.
chameleontuning
Alright awesome lol ..I may have some more... I just been using the program for so long I learned work arounds ..
Off the top of my head the record button very often doesn't stay "selected" so for instance I'll record a run and I'll forget to hit stop because it doesn't have the "pressed" or "selected" look.
There is another bug in the graphing of the logs.. you can move the cursor and AFR line will disappear completely and only reapear if your in specific spots.. 😅
