Flex fuel tune
05 s2k turbo
Flex fuel tune
Post by 05 s2k turbo »
So when tuning flex fuel do u adjust fuel map when you put e85 in or just adjust the settings in the flex fuel parameters?
Re: Flex fuel tune
If you have been tuned properly for regular fuel, then you should only have to make adjustments to the flex fuel settings.
05 s2k turbo
Re: Flex fuel tune
For example im tune 93 on 15psi so it's got a proper tune but I want to turn it up to 20psi do I need to adjust the fuel map?
Re: Flex fuel tune
You should have your tuner make sure it is safe at the higher boost level.
