Flash pro
Christian1221
Flash pro
Hi so I’m having trouble getting the program to read my Hondata flash pro I was able to manually download the drivers but it won’t read it once it’s plugged into my computer any help would be greatly appreciated
Re: Flash pro
What is the serail number that is on the FlashPro?
Re: Flash pro
Christian1221
Re: Flash pro
Windows 11 and the most recent versions of flash pro
Re: Flash pro
I need to know the actual version of software you are using from Help, About.
Re: Flash pro
When was the last time it was working?
What has changed since then?
Christian1221
Re: Flash pro
Probably 2021 the vehicle has been down for a guest years so the issue is it works on my car I can connect to Bluetooth and everything but when I plug into computer it’s gets power but the usb light doesn’t come on
Re: Flash pro
What has been changed on the vehicle since it was last working?
Christian1221
Re: Flash pro
Nothing vehicle is still the same but the issues is the computer doesn’t read it when it’s plugged into the usb port so the actual program isn’t reading the flash pro device
Re: Flash pro
Send an email to support <at> hondata.com with the following and I will issue an RMA and give you further
instructions:
Name:
Address:
Phone:
Email:
Serial#:
Description of problem:
include a link to this thread.
instructions:
Name:
Address:
Phone:
Email:
Serial#:
Christian1221
Re: Flash pro
Okay thank you can you provide a link so I can find the email?
Christian1221
Re: Flash pro
Okay I just send the email thanks
