K24a JDM Starts But No Idle
ArcSol77
Post by ArcSol77 »
Hello, I've been working on a K Swap in a Del Sol, I have everything installed, and am now trying to get it running properly so I can finish burping the coolant and then move on to figuring out how to street tune it myself.
At one point, the car ran on one of the Hondata K24A base tunes, and I was burping the coolant. Everything was running fine, when I was burping the coolant, until the afr randomly spiked to about 20ish, and then it abruptly shut off. When I went to start it again, it cranks then starts very briefly, rpm reaches about 1k, then drops down to 0. I thought it was the p0335 code I had, but I just recently finished fixing the crank sensor and now the code is gone, but I still have the same "crank then immediately dies" issue. I'm not sure if it just needs a different tune, or if the injectors aren't firing, and is just starting off the primed fuel.
I have a datalog of it, hopefully the link works:
https://1drv.ms/x/c/6358ee24f613201f/IQ ... U?e=XGibcg
Setup:
K24A JDM (RB1)
KPro V4 + Wideband 02 sensor
Rywire Tucked K Swap Harness
Hybrid Racing Fuel Pump + Press. Reg. Set at 55PSI
Hybrid Racing Fuel Rail w/ Stock Injectors
4-2-1 Exhaust Manifold with 3" Exhaust
RBC Intake w/ 60mm TB + Hybrid Racing Cold Air Intake.
Re: K24a JDM Starts But No Idle
Are you using the original K24 crank sensor?
ArcSol77
Post by ArcSol77 »
Yes I’m using the stock k24 sensor that came with the motor. And the harness connector has been repinned to be compatable.
It may not be pinned correctly.
ArcSol77
Post by ArcSol77 »
I used this diagram from Hybrid Racing, and afterwards I checked all the pins with a voltmeter, making sure the Circuit D04 was reading 12v with ignition on, checked that CKP had continuity with Pin 7 on the A ecu plug. And checked the G101 was grounded. After I repinned it, the check engine light went away, but the car won’t idle still, just starts, then dies.
CalibratEd
Post by CalibratEd »
I would double check the wiring. I have had several people run aftermarket harnesses and encounter similar issues.
- Ed
Instagram: calibrated.tuning
ArcSol77
Post by ArcSol77 »
I fixed the p0335 issue. Still won’t start. At some point it gave me a p1361. I messed with it and the code went away. But when I crank Commanded CAM = 0 but it’s reading 107°. I can drop a screenshot of the graph. At some point the ignition timing was so off it backfired on the intake stroke.
