cannot upload files to flashpro and ecu
SWERyan
Post by SWERyan »
Im having problems uploading tune to the flashpro and to the ecu. When I press upload status bar displays for 3 secs then disappears.
live tuning is working and datalogging also. I cant upload the file to the car. calibrations tab also shows blank. This happened today while adjusting the tune. This flashpro has been with the car for more than a year already. could this be a failed firmware update on the flashpro mini? It asked to unplug from the vehicle because it the firmware will be updated.
just to add i have been using this flashpro manager version with no problems
hondata flashpro 4.7.3.0 build 5646
does anyone have inputs?
SWERyan
Re: cannot upload files to flashpro and ecu
Post by SWERyan »
looks like the secondary map is able to accept file. I was able to load manually the secondary map. But the primary map and loading the map thru PC Flashpro manager will now work. Is there a fix to this?
jonesy.fl5
Post by jonesy.fl5 »
Did you ever figure this out? I'm having the exact issue. I click upload and the window pops up for a sec then disappears.
jonesy.fl5
FlashPro Manager 4.6.3.0
FlashPro Mini FP-CTR-358541
Update your software. You are two versions behind.
