Wideband O2 AFR D14 to D10
MrHeeltoe
Post by MrHeeltoe »
Hi this might be elementary, I have the PLX 0v-5v wired to D10. What do I do with D14 pinout and the heater circuit? Remove the pins? Then by configuring s300 to look to d10 for the AFR does that automatically prevent an mil with D14 And the heater circuit open? I feel like I've got the AFR installed correctly I just don't want to have any problems with the pre-existing circuit. I can't really find any instruction on what to do with it.
Re: Wideband O2 AFR D14 to D10
You do not need to do anything with the wiring. You can disable the heater error in the software.
MrHeeltoe
Post by MrHeeltoe »
Thanks, Matt. Appreciate that.
Since I am wiring a few other circuits with the harness, I could use the D14 and Heater circuits for other stuff, like boost controller, Fanc, and other non-existing leads in my chassis (85 JDM Si). Sounds like I am safe to depin those locations then and repurpose the wires in new pin locations and on the other end of the harness?
as long as they are not used and no longer connected to where they used to go.
