ECU Analog inputs
Asura
ECU Analog inputs
Post by Asura »
Hi
I know that https://www.hondata.com/help/flashpro/e ... htsub=ECT2 shows the pins on the ECU you can use for inputs, and I know there are multiple places in the software where you can tell the flashpro/ECU what's being used for what (Like the Ethanol sensor under Ethanol, or the Wideband input under Closed Loob -> Lambda, I was wondering if there were also locations where I could set up things like fuel pressure/temp, oil pressure/temp, etc.
Re: ECU Analog inputs
No there is not option for this with the FlashPro.
