Hondata for the K20A
Guest
Post by Guest »
rumor has it that its coming out for the RSX/civic si. will the intake cam timing have it's own MAP similar to fuel and spark?
ptracy26
Post by ptracy26 »
OK, the flash upgrade for the RSX Type S is out now, but will the s200 system work with this car instead of having to get this upgrade?
Thanks.
whoojong
Post by whoojong »
nope.
02-sir
Post by 02-sir »
Is it me, or was the Civic Si taken off the R&D priority list for ECU flash upgrade?
will it no longer be available? :(
02-sir
Post by 02-sir »
nevermind, the site's been restructured with several different R&D priorty lists.
An update on the Civic Si progress would be cool none the less.
PoRT
Post by PoRT »
any info on this? patiently awaiting 02 Si flash :lol:
sancho61
Post by sancho61 »
What happened to the 2002 SI priority?
Klutch RSX
Post by Klutch RSX »
i just got the K20a3 flash for my base model RSX 5 speed. (should be comeing tommorow) Monday. :lol:. you would think the ECU for hte 02 Si is pretty much the same as the rest of the k20a.. especially with the k20a3 (base model) the engines are the same pretty much. i dunno whats up. but they will release a flash sooner or later for the Si.
good luck
Nick
currently the fastest base rsx in the country. n/a no nos either
importhonda
Post by importhonda »
So what exactly is the differenc between the k20a3 in the rsa and the one in the SI? Is it just the intake manifold? Don't we share the same manifold as the k20a?
Dookie
Post by Dookie »
Does Hondata anticipate a new program for the K20A2 to implement the addition of headers and exhaust?
