Base Map?
never2low
Base Map?
Post by never2low »
ok, i am building a 1991 Acura Integra GS. It has a B20B4 block, B16A2 PR3 V-TECH head. I am also installing a T3 turbo with frount mount intercooler and 2 inch pipping.I am using the factory wiring harness which is an OBD0 plug harness and i am converting to an OBD1 with an adapter harness. The 2 questions i have are:
Using a connector pinout can the V-Tech wiring be tapped into the adapter harness?
Which ECU would be best to use with this setup and can hondata sell the ECU already tuned specifically for the modifications that i have made?
You can use a 92-95 P28, P30 or P72 ECU, US or JDM Remember to change the distributor to OBDI The adapter harness should have the VTEC wires included.
Sorry, we don't provide custom tunes.
