kpro + water injection kit questions
tt061880
Post by tt061880 »
Can I use the nitrous control in the k-manager as the controller for water injection kit? Will the wiring and everything going to be as same as a nitrous kit? Also, I've never run nitrous with kpro before so let me ask this question. In the kmanager, the nitrous control will be enable, but the nitrous parameters only activate when I turn that arm switch right? Please give me some pointers on how to go about this setup, thanks in advance.
You can use the nitrous control to run water injection. Read the KManager help file in the 'nitrous section' The nitrous will not activate until the arm switch is swtiched on. With water injection it is possible to removed fuel (you can do this with a negative nitrous fuel amount). It might pay to use a low water level switch wired into the arm switch so that you don't run out of water and keep running the engine with less fuel.
