manual to automatic
never2low
manual to automatic
Post by never2low »
My 1994 Integra LS is an automatic. I am converting to a GSR manual transmission and i am tring to figure out if there are any wires that a will have to change or sensor i will have to bypass to do so, and i am trying to find out if if the computer for the GSR will work.
Are you changing the engine?
never2low
Post by never2low »
yea, i'm swaping in a CRV-TECH that i built with a T3 turbo.
RMS
Post by RMS »
you will have to wire in the clutch interlock and the reverse lights. nothing else that effects the ecu is a problem.
RaVer Motorsports (559) 733-4711
ravermotorsports@earthlink.net
never2low
Post by never2low »
for the clutch interlock and reverse lights, am i just going to bypass sensors with a wire changing the wiring in the harness?
RMS
Post by RMS »
from the shifter plug you will have to run two wires over to the clutch switch. from the shifter plug you will also have to run two wires to the transmission's reverse switch...i think that is all.
