P2T to PCT ECU or Better?
llgarcia
Post by llgarcia »
I have a B16 3rd gen whose stock ECU is the P2T. I changed to PCT (Civic TypeR) ECU since I modified to Type R head, typeR pistons, etc. Any better ECU I can apply?
To use a Hondata system, you will need to use one of the compatible OBD1 ecu from the list at http://www.hondata.com/ecus.html and you can then use the Hondata s100 or s200 system.
llgarcia
Post by llgarcia »
Tnx a lot! Any particular OBDI ECU you can recommend?
