05 K20Z1 motor running on K20A2 ECU
mr. mis-shift
Post by mr. mis-shift »
http://forums.clubrsx.com/showthread.php?t=239778
in this thread it looks like they managed to get a 02-04 ECU to work on a 05 motor. is it possible?
The difference between the 02-04 and 05 RSX is the ECU, vehicle wiring and transmission. The engine is the same, so using a 05 short block in an 02-04 RSX doesn't change anything.
mr. mis-shift
thanks for the prompt response.
i'm not sure if i'm reading it correctly, the 05 block is backwards compatible with 02-04 components starting from the 02-04 block wiring and all the way through to the 02-04ECU?
hondapwr
Post by hondapwr »
it is not the same the cams are type R. In that post, the kid says he knows for a fact now that the head was also replaced, meaning he got the cams too. With his setup(i/rh/e), and that motor with K-pro, he can make about 235-240 whp. He got hooked up
Jason Couture of Newport News, VA
Current Ride:
2005 Blaze Orange RSX-S (picked up 11-3-04)
Mods: Greddy Evo2 Cat-Back
Injen CAI
B&M STS with ClubRSX shift bushing kit.
Previous Ride:
2004 Arctic Blue RSX-S
Ratio
Post by Ratio »
Well the cam serial numbers for the type r match those of the 05 type s.
"We can't stop here...this is bat country!!"
