fuel - tuning 1st column
dnatrance
Post by dnatrance »
ok I have finally gotten the hang of the hondata system and have gotten pretty good at it. The only thing I am having trouble with is tuning the first colum. I can never get the motor in that colum to get any readings on whats going on, even at idle. I am at about 280mb, 800rpms at idle.
The only reason I am concerned about this column is when let off the throttle, say in first gear at low rpms and start to apply throttle the car jumps. at around 1-4 % opening of the TPS it doesnt feel like the engine is doing anything then around 5-6 it just jumps.
Any advice would be appriciated
oh btw I have a stock JDM b18C
What is your TPS voltage at idle?
dnatrance
Post by dnatrance »
.45
Twitch
Post by Twitch »
I get the samething
Try adjusting your TPS so that it reads .49 at idle. Also try disconnecting your idle control valve when the car is warm and idleing..it should idle at about 400-600rpm, if it does not you have an air leak.
