Disabling EGR and crank sensor?
SuperDave
Post by SuperDave »
Is it possible to eliminate the egr and the crank sensor on a S200 system?
The engine is a H22A4 in a EJ1 runing on a USDM P72.
Any help would be apreciate.
Swapping to an OBDI ECU will allow you to remove the EGR and crank sensor. If the engine has an active diff it will be disabled.
SuperDave
Post by SuperDave »
Hondata wrote:Swapping to an OBDI ECU will allow you to remove the EGR and crank sensor. If the engine has an active diff it will be disabled.
OK,my P72 is already OBD1.So if I read you good,the answer to my question is YES.
Thanx
