greddy turbo k20a3
blanblu
greddy turbo k20a3
Post by blanblu »
Hondata,
there seems to be a bit of mystery regarding the existence of a reflash or even a base map for this setup... so i would like to know directly from you whether or not a reflash is available... or if there is a base map that comes with k-pro... thanks in advance...
We only have a Greddy reflash for the Type S. We have calibrations for the K20A3 Civic Si with 440 and 550 cc injectors with the K-Pro.
blanblu
Post by blanblu »
Hondata wrote:We only have a Greddy reflash for the Type S. We have calibrations for the K20A3 Civic Si with 440 and 550 cc injectors with the K-Pro.
i know i would have to flash back to stock prior to going greddy (if i want to just use emanage that is)... so, which profile would that be on your kmanager software?
k20a3-civic-factory.kal or k20a3-base-factory.kal
and what's the difference...?
i purchased the na reflash thru a shop that is now out of business, i want the kpro upgrade but i don't want to pay full price for it... what do you suggest doing?
thanks
dc
blanblu
Post by blanblu »
also, if i were to not get kpro, how much would it cost to simply get the ecu flashed back to stock setting?
thanks again!
dc
k20a3-civic-factory.kal is for the Civic Si and k20a3-base-factory.kal is for the Base RSX
To upgrade to a KPro contact another dealer.
To reflash back to stock is $75 incl. shipping.
blanblu
Post by blanblu »
Hondata wrote:k20a3-civic-factory.kal is for the Civic Si and k20a3-base-factory.kal is for the Base RSX
what psi is the 440 greddy kal tuned for?
thanks!
