How to tune the MAF on an FL5
qinyuan.zou
When I tune the MAF on the FL5, should I refer to the short-term fuel trim (STFT) or the total fuel trim value?
Re: How to tune the MAF on an FL5
You will want to look at the AF and the short term trim.
qinyuan.zou
Sorry, I didn't catch that. Did you mean looking at the difference between AF and AFCMD?Could you explain it in more detail?
You will need to look at both and make necessary adjustments to the areas that need more or less fuel.
qinyuan.zou
Thanks, I'll give it a try.Spunkster wrote: Tue Mar 17, 2026 11:55 am You will need to look at both and make necessary adjustments to the areas that need more or less fuel.
You should use Total Fuel Trim (STFT + LTFT) as your main reference when adjusting the MAF curve.qinyuan.zou wrote: Mon Mar 16, 2026 8:23 am When I tune the MAF on the FL5, should I refer to the short-term fuel trim (STFT Geometry Dash) or the total fuel trim value?
qinyuan.zou
I tried, but from the logs I found that the short-term fuel trim (STFT) for many ranges is -0.5%, long-term fuel trim (LTFT) is 0, and the total fuel trim is -1.5%. So I don’t know whether to base it on STFT or total fuel trimsoloth wrote: Wed Mar 18, 2026 11:53 pmYou should use Total Fuel Trim (STFT + LTFT) as your main reference when adjusting the MAF curve.qinyuan.zou wrote: Mon Mar 16, 2026 8:23 am When I tune the MAF on the FL5, should I refer to the short-term fuel trim (STFT Geometry Dash) or the total fuel trim value?
it sounds like your trims are already dialed in pretty well.qinyuan.zou wrote: Thu Mar 19, 2026 12:48 amI tried, but from the logs I found that the short-term fuel trim (STFT) for many ranges is -0.5%, long-term fuel trim (LTFT) is 0, and the total fuel trim is -1.5%. So I don’t know whether to base it on STFT or total fuel trimsoloth wrote: Wed Mar 18, 2026 11:53 pmYou should use Total Fuel Trim (STFT + LTFT) as your main reference when adjusting the MAF curve.qinyuan.zou wrote: Mon Mar 16, 2026 8:23 am When I tune the MAF on the FL5, should I refer to the short-term fuel trim (STFT Geometry Dash) or the total fuel trim value?
