Euro FK8 P0369
CivicVTi
Euro FK8 P0369
Post by CivicVTi »
Hello. I have an intermittent P0369 (most of the times CEL triggers on cold starts). Have replaced sensor, nothing changed. The weird thing is that I have also disabled this CEL in hondata menu but it still comes on. ANy ideas?
Re: Euro FK8 P0369
It sounds like there may be a wiring issue.
CivicVTi
Re: Euro FK8 P0369
Post by CivicVTi »
ANy chance this could be linked with a 'money shift'? WE replaced the intake camshaft with the notorious trigger shift issue and we interminttently get this CEL (mainly during cold/overnight cranking). We also replaced chain and tensioner and also exhaust cam gear. CAn this be attributed to oil pressure? (although we get normal readings).
Re: Euro FK8 P0369
If you return to stock form the online menu and still get the error, then you should have Honda take a look at it.
CivicVTi
Re: Euro FK8 P0369
Post by CivicVTi »
Problem is that it also has Hondata fuel system so not easy to revert to stock.
Re: Euro FK8 P0369
Either way I would recommend having Honda take a look at it.
CivicVTi
Re: Euro FK8 P0369
Post by CivicVTi »
Ok, although I really doubt they can help (car is not located at the US at the moment). If I were to dig a little more to the problem, do you have any suggestions about where to start? (after checking plug and wiring of course).
