L15b7 swapped EG flashpro
Civic 2016+ 1.5 Turbo
Fkn SingleCam
Post by Fkn SingleCam »
Im coming here to see if someone has any insight on this issue. I swapped my eg with an L15b7 and while cranking my injector ms and duty cycle stay at zero. If I add starting fluid in the intake the engine starts and everything runs perfect. I can drive around all day with no issues. The moment I turn it off it wont start again unless I use starter fluid. Immobilizer is not activated since the swap flashpro has removed it and it shouldn't stay running if the immobilizer was active. Low side fuel pressure is set to 60psi. High side cranking reaches over 1200psi. Im hoping its just some tuning issue where I have to add cranking fuel but im not seeing such option on flashpro. Anyone have a clue what the ecu is looking for during cranking to command the injectors on?
Re: L15b7 swapped EG flashpro
Post the calibration and datalogs showing what it is doing.
