problem with map: Civic Si Turbo MT 2017, high octane +6 PSI via Sport button and FTS
Civic 2016+ 1.5 Turbo
Angel Muñoz
Post by Angel Muñoz »
Hi, I loaded the map: "Civic Si Turbo MT 2017, high octane +6 PSI via Sport button and FTS," however, when checking the datalog in normal and sport modes, it reaches 20 PSI. I don't see an increase in sport mode; honestly, I don't see the difference, and I see that it reaches the +6 PSI in normal mode.
I have the option "Sport button boost (Hondata mode) enabled," and I've already adjusted the torque table in normal and sport modes, but there's no improvement.
Torque limit normal (250 default) , adjust to 260 nM
Sport torque limit (650 default), adjust to 380 nM
Following Hondata's recommendations, I also tried enabling "Scramble (max boost) enabled" and "Enable scramble via sport button," however, with that configuration, in normal mode it reaches 20 PSI, and in sport mode, only 17 PSI.
Does anyone know what I can modify? I'm interested in having 14-15 PSI in normal mode and +6 PSI (20 PSI) in sport mode.
Re: problem with map: Civic Si Turbo MT 2017, high octane +6 PSI via Sport button and FTS
Post the calibration and datalogs showing the issue.
Angel Muñoz
Spunkster wrote: Tue Apr 28, 2026 2:18 pm Post the calibration and datalogs showing the issue.
Hi
Only Sport button boost (Hondata mode) enabled
I'm sharing the datalog; the first pull is in sport mode and the second in normal mode.
I'm sharing the calibration used
datalog2804 sport and later normal.fpdl
high octane +6 PSI via Sport button and FTS V.5.fpcal
___________-
Scramble mode
I'm sharing the datalog; the first pull is in normal mode and the second in sport mode.
datalog2204 normal and later sport.fpdl
high octane +6 PSI via Sport button and FTS V.2.fpcal
Angel Muñoz
can you help me please
The boost pressure is very closely matching the commanded boost pressure in both datalogs.
Angel Muñoz
What adjustment do you recommend in the calibration?
Angel Muñoz
any recommendations?
Open a new calibration with that enabled and do not make any other changes and make comparisons between the modes then.
