FlashProManager 4.7.1
4.6.7 (11 May 2026)
· Firmware updated to version 279
· [2019+ RDX] Added support for 2022 model 5YF-AE2 USA
· Improved CANFlex operation
4.6.8 (12 May 2026)
· Firmware updated to version 280
· Fixed update process for older FlashPro
4.6.9 (15 May 2026)
· [FK8] Fixed 2019-2021 US models not allowing instant jailbreak
4.7.0 (18 May 2026)
· Firmware 281
4.7.1 (21 May 2026)
· Firmware 282
If you have an EBCAN purchased in the last two weeks which has a serial number on it then unplug the EBCAN when uploading. That will not be necessary after the next release which will update the EBCAN firmware.
Download here
Please only post in this thread if directly related to the software release. It is the place to request features.
dmoraroj
Re: FlashProManager 4.6.8
Post by dmoraroj »
Question: what issues did you capture with the 4.6.7 version? Is it something related with the "Improved CANFlex operation"? or with the Flashpro Firmware itself?
AllenZhangFE3
Post by AllenZhangFE3 »
dmoraroj wrote: Tue May 12, 2026 6:42 pm Question: what issues did you capture with the 4.6.7 version? Is it something related with the "Improved CANFlex operation"? or with the Flashpro Firmware itself?
try update to 4.6.8,i cant upload tune to ECU with 4.6.7,fixed in .8
dmoraroj
Post by dmoraroj »
I just did, but the FP still doesn't comunícate with Manager app
dmoraroj
Post by dmoraroj »
I did that with both versions.
What is your serial number?
dmoraroj
Post by dmoraroj »
FP-2012SI-118115
replied via email
dmoraroj
Re: FlashProManager 4.6.9
Post by dmoraroj »
I just notice that firmware version has been rolled back to 279 in the FlashproManager4.6.9, I will try tomorrow and see if it solve my issue and let you know.
dmoraroj
Post by dmoraroj »
Same result....
Netopsengineer
Post by Netopsengineer »
Your download link also isn't working for this version, and when I attempt to update Flashpro Manager from the software itself I'm on 4.6.6.0 on Windows 10, as soon as I click update it tries to launch `update.exe` like normal but I get:
Title: Unsupported 16-Bit Application
Message: The program or feature "\??\C:\Users\my_user\AppData\Local\Hondata\FlashPro\update.exe" cannot start or run due to incompatibility with 64-bit versions of Windows. Please contact the software vendor to ask if a 64-bit Windows compatible version is available.
My installation:
Edition Windows 10 Home
Version 22H2
Installed on ‎8/‎10/‎2025
OS Build 19045.6466
dmoraroj
Post by dmoraroj »
dmoraroj wrote: Fri May 15, 2026 2:48 pm Same result....
Somehow the device sometimes it seems is able to comunicate with Manager and in that I try to upload a file and shows the error in the image.... I think it is done.... what I see is the FW 279 caused a failure in a memory component inside the FP.
EJHonda
Post by EJHonda »
Netopsengineer wrote: Sat May 16, 2026 2:42 pm Your download link also isn't working for this version, and when I attempt to update Flashpro Manager from the software itself I'm on 4.6.6.0 on Windows 10, as soon as I click update it tries to launch `update.exe` like normal but I get:
My installation:
Version 22H2
OS Build 19045.6466
Same error messages here when attempting to download 4.6.9 from 4.6.6.0 Build 5835.
Edition Windows 10 Pro
Version 22H2
Installed on ‎9/‎26/‎2020
OS Build 19045.7291
Jester04
Post by Jester04 »
EJHonda wrote: Sat May 16, 2026 9:34 pm
My installation:
Version 22H2
OS Build 19045.6466
Version 22H2
OS Build 19045.7291
I’m getting the same error message, went to download the software since the last version bugged out. Now can’t even download the software from the website.
I’m flashpromanagerless🤣
