Working on finishing up a k24a JDM k swap. I had it running at one point but eventually it stopped working, and fixed the Crank Sensor wiring. I noticed it was reading 107 deg cam angle, so I bought and installed known working sensors for both the TDC and CPS sensors. After doing a continuity test on the Budget K swap harness from Rywire I found it wasn't labled or pinned properly, and it had the 2 cam sensors plugs swapped, I swapped them so they feed to their proper pin on the ECU connector A. Now when I crank it starts for a half a second and then read cam position jumps to 107 Degrees, and the rpm plateaus and the engine dies. I tried locking the VTC to 0 in kpro and cranked again and it read cam position as 0 but the rpm would still plateau and the motor would die. I dont know if it has something to do with the 50 deg VTC gear being slightly off/ not homing at 0 properly.
I will provide some images of the kpro readings, and another of the timing chain and cams:
https://drive.google.com/drive/folders/ ... drive_link
Setup:
K24A JDM (RB1)
KPro V4 + Wideband 02 sensor
Rywire Tucked K Swap Harness
50 Deg VTC Gear
Hybrid Racing Fuel Pump + Press. Reg. Set at 55PSI
Hybrid Racing Fuel Rail w/ Stock Injectors
4-2-1 Exhaust Manifold with 3" Exhaust
RBC Intake w/ 60mm TB + Hybrid Racing Cold Air Intake.
K24a JDM 107 Deg Cam Angle
Jump to
- General
- ↳ Hondata News
- ↳ Applications
- ↳ Non-Hondata
- s100/s200/s300
- ↳ s300 / SManager
- ↳ S300 Calibrations
- ↳ SManager Display Templates
- ↳ s100/s200
- ↳ Romeditor 4 Software
- ↳ HondaLogger Software
- ↳ Coil Pack Retrofit
- K-Series
- ↳ K-Pro / KManager
- ↳ K-Pro Calibrations
- ↳ KManager Display Templates
- ↳ K-Series Reflash
- FlashPro
- ↳ FlashPro Manager
- ↳ FlashPro Calibrations
- ↳ Accord 2008+ FlashPro
- ↳ Civic Si 2006-2011 Americas
- ↳ Civic Si 2012-2015 US/Canadian / 2013+ ILX
- ↳ Civic Type R 2006-2010 Japanese FD2
- ↳ Civic Type R 2007-2011 European FN2
- ↳ Civic Type R 2015+
- ↳ Civic 2016+ 1.5 Turbo Americas/Asia
- ↳ CRV 2017+
- ↳ CR-Z 2010-2012 US/Europe/Asia
- ↳ Fit 2007-2008
- ↳ RDX 2007-2012
- ↳ S2000 2006-2009 Americas/Europe/Asia
- ↳ TL 2007-2008
- ↳ TSX 2004-2014
- Traction Control
- ↳ General / Traction Control Manager Software
- ↳ Traction Control with S300
- ↳ Traction Control with KPro
- ↳ Traction Control with FlashPro
- Bluetooth Mobile Apps
- ↳ Hondata Mobile
