2006 RSX nitrous control pin out
13btoy
Post by 13btoy »
Hi all. On a 2006 RSX Type S with a V3. Which pin out do I use to utilize the nitrous control? I’m actually going to use it for water injection. Thanks in advance!
Re: 2006 RSX nitrous control pin out
The wiring diagram for this can be found in the help file at: https://hondata.com/help/kmanager/nitro ... ub=nitrous
13btoy
Post by 13btoy »
Thanks for your response. I did see that diagram. I was told that the pin outs would be different for the 05-06 RSX because of the jumper harness. I just wanted to make sure.
Thanks, Ed
The pinout from the ECU is 02-04 as an 02-04 ECU is used.
